Carburetor flooding??
Greetings everyone, Lewis here again from Monterey, TN. After putting new gas line, new fuel pump, cleaning carburetor and taking the gas tank out and having it cleaned I still had problems with the 18 hp B&S idling. I ended up getting a new Nikki carburetor and installing it. Now it idles really good but another problem has cropped up. It backfires out the exhaust and up through the carburetor. I suspect the mixture is too rich, building up gas in the muffler causing it to backfire. Also, when I open the throttle pretty quickly you can see droplets of gasoling being blown out the top of the carburetor and there is a considerable lag time in the throttle. I haven't found any adjustments on the carburetor to lean down the mixture and since it is idling good I hesitate to mess with the idle mixture screw. I was wondering if someone else has had the same problems and how they fixed them. Any help would be appreciated... It seems like this thing is slowly devouring money and I am getting nothing in return except more work on it. Thanks for any help/suggestions.... Lewis
