kawasaki 20 hp upgrades
  • kawasaki 20 hp upgrades
    has anybody tried to hop up one of these engines, if so can you let me know what all you did. would really like to get a little more out of it, john deere gators are up to 33 hp with a kawasaki v twin, fd620.
    mud and ice
    pipe
    filter
    cams
    tune the clutch better
      There's a guy who builds air cooled kawasakis, I'll look him up and ask.
        We had a couple E mails:
        Hi Jason,
        I see from Heymow you do kawasakis. My hobby is 6 and 8 wheel amphibious atv's. One model has the fd620, and some owners would like to get more power. Do you deal with the water cooled or know what's available for it?
        Some of the things we do with the air cooled FH twins will work on the FD620's (cam regrind as long as it has the metal cam gear, valve springs, porting, milling cylinder heads, etc.) but things like our flywheel don't work on them. There are a few guys running the Liquid cooled engines in pulling garden tractors, and I know there is someone making a high dome piston for them. Are you guys still using the governor system?
        I will try to spend a little time and join the site so I can help respond to questions like that. The cam mod probably won't do much good on a governed engine because more than anything changes the rpm at which it is most efficient, and the stock profiles are designed to do that at 3600 rpm. Compression will definately help, more snap to push the piston down. Porting will help if its done right, help the engine breathe at the desired rpm. I will be happy to help where I can.
          this is great
          thanks for all the input, i was not sure that there was this much avilable for these engines, i will try to get all of the info from the engine and place it in on here. engine code is fd620d-ds12 and family no is ska617ug2ra. i look forward to hearing more.
          Thanks again
          Darin
          mud and ice
            Thanks again
            Darin
            Hi Darin
            Was told by a reliable source(Argo Dealer) about these 20 hp Kawasaki engines that you need to keep a fuel stabilizer added to the fuel to keep the valve train from giving any problems. Ran the stabilizer in mine and never had any problems. The problem occurs when you let it sit for a extended amount of time. Fuel stabilizer is kept in my gas at all times. You may or may not know this, just though i would give you a heads up. Everyone has different brands that they like.
            Lewis
              fuel tip
              that is good to know, i think i will start with pulling the carb and cleaning it, i don't know if the po ever knew that, after spending 2 days cleaning and oiling chains, also fixing the reverse gear. i have a feeling that he was not as concerned with maintance. i will still have to go through the rest of the machine before hunting season, just looking to get the most hp with realibilty.
              Darin
              mud and ice
