Hey guy's,
I recently rebuilt my carb and reinstalled it. I would first like to say that I have the Vanguard repair manual, and the original manual that came with the engine. Both have instructions on how to adjust or set the carb, additionally i have printed the instructions from the "how to" section of this site. All of the instructions are for the most part identical. I also purchased a tach to make the process easier.
1. When i turn the idle mixture screw clockwise to find the point where the rpms just start to drop (lean), as the instructions describe, it never happens. I can turn the mixture screw until it is seated. The rpm actually climb from 1300 to around 1600 then level off, which boggles the sh*t out of me?
I do get the rpms to drop when i turn the other direction (counter clockwise or rich) but for the life of me I cant find the lean side.
2. Also the directions say to set the idle rpm initially to 1400 for a red governor spring and to 1100 rpm for white governor spring. I can't tell which spring that i have. Does anyone know what spring or rpm setting I should be using?
Thanks to all that reply, your help an knowledge is greatly appreciated by this newby.
