Hi Guys I need some help.
My 84 argo response won't start. I had the same problem last time I used it several weeks ago (-20C) but eventually I got it going. I fooled around with it for several hours this afternoon and the best I could get were about six or seven "almost starts" but with each of these the engine only fired about 4 to 8 times then died
. The outside temp when I first tried to start it was -10 c. It eventually warmed up to -3C but still no luck starting.
It seams to be flooding because each time I pull the plug it is wet with fuel. I checked the plug I am getting a good spark. I checked the compression and am only getting 70psi. The engine is the Techumce 18hp and it has 500 hours on it.
Any suggestions? Is it a carburator issue or poor compression?
What compression should I be getting?
. The outside temp when I first tried to start it was -10 c. It eventually warmed up to -3C but still no luck starting.It seams to be flooding because each time I pull the plug it is wet with fuel. I checked the plug I am getting a good spark. I checked the compression and am only getting 70psi. The engine is the Techumce 18hp and it has 500 hours on it.
