Hello everyone. Wanted to start by saying that you all have a wonderful website! The boards, gallery, etc., etc. is amazing and there seems to be some extremely knowledgeable members too.
I am somewhat new to the world of ATV’s. I was given a 1974 Cushman Trackster and a 1980 Hustler. I had the Trackster running 6 or 7 years ago but due to a job relocation, etc. I wasn’t able to tinker with it anymore. It hadn’t run in over 20 years, so working on it was a challenge, but the fun I had on it certainly made it worthwhile. Hopefully once I get the Hustler running properly, I'll get the Trackster primed and running once again.
Most recently I have been playing around with the Hustler, but am having a very difficult time getting it to run properly. I need your help! The Hustler was parked in about 1983 and never messed with until last year. It has the 16 Hp K341 Kohler engine. To date, I have replaced:
• Fuel line and filter
• Fuel pump
• Carburetor
• Coil, points, condenser, spark plug, & plug wire
It will start and run all day long, but as soon as I attempt to rev it up, it “falls all over its face” and attempts to die unless I let off the gas. I’ve adjusted and readjusted the new carburetor (the old one would only run full choke, but the new one runs w/ the choke wide open) but it still seems to be running somewhat rich. The plug is also pretty black after running it. Obviously I don’t know a great deal about small engines, but it seems to be a timing problem to me. I believe I’ve set the points correctly (assuming TDC is when the piston is at its highest position when viewed through the spark plug hole...again, I'm no mechanic), but am not sure if there is some other sort of timing method I should use. It also has a slight knock when revving it up, so I’m not sure if it’s more serious than I think. Does anyone have any suggestions for me???! I'd like to repair it myself in lieu of taking it to a shop, although my wife would probably appreciate me giving into my temptations and just have someone else fix it for me!
I appreciate the help and once again, great site!
• Fuel pump
• Carburetor
