Hey Guys,
If you've been reading the ASX tire thread, then you know that I am looking for some more torque/HP for the 18 Vanguard.
What are your thoughts?
Here is what I have done so far. Installed double valve springs and billet spring retainers from EC Dist. Also installed thin head gaskets. Have the stock flywheel key. I have a cutaway, but didnt see much difference so I went back to the stock.
I would prefer to add on some easy bolt on's without doing the cam right now. If that is not possible, then I might as well do the long billet rods, cam and shaved pistons.
What are the thoughts about a lightweight flywheel, different carb or carbs, modifing the stock carb, modifing the exhaust.
If you have links for suppliers, that would be great. I have been researching a little about cams, and would prefer one from new stock materials that have not been welded on.
Thanks in advance for your help,
Rut
Rut
Pull the 18 briggs sell it, and install a 25 or 30hp kohler with big clutch. You'll be glad you did, there is nothing better than having enough power at hand when you need it
I had a max iv with 18briggs 70% of the time it was ok 30% I was unhappy
