Wiring help for Tecumseh 16hp in max iv
  • Wiring help for Tecumseh 16hp in max iv
    Hi Guys,
    I'm stumped (easy for a newbie). I've circled the wires in the attached picture that don't currently connect to anything. I know something isn't grounded properly since the motor won't shut off with the key, and nothing seems to be going back to charge the battery. Can someone markup this image showing where to connect these wires? Thanks!!!!
    John
    jcollier@meadownet.com
    You could contact Recreatives Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 and they would most likely be able to help you out with it. They have manuals and just about any part you could ever need to fix your problem.
      Recreation
      I did, and they sent me a wiring diagram which I used to wire up most of it, but I can't decipher from the diagram where the circled wires in the picture go.
        max
        looks like the one with the eyeloop is a ground,the one that is flat goes to the black plug
          Black Plug
          If the white wire with the flat end plugs into the black plug with the two female flat connections (green wire side, I'm assuming a ground) does the other female flat connector (red wire) go back to the battery (for charging)?
          The one with the eyelet is red, doesn't that mean it's live, not a ground?
          So confusing
            So confusing
            I would take a multimeter or a test light on it first to make sure its not.
              red with eyelet
              One down, the red wire with the eyelet is power to the headlights ;-)
                picture of max iv and oh160
                Hi,
                I'm waiting on a new ignition module for my oh160 to arrive and I'm nervous about how things are wired (on not). Anyone with a max iv and oh160, could you take a picture of your engine compartment, especially, showing how it's wired up? That, coupled with the helpful descriptions I've received of how it should be wired, should help this newbie get everything back together, and not blow another module. Thanks!
                Last edited by Mike; 07-05-2009, 10:46 PM. Reason: moved post to existing thread (no need for two threads) :cool:
                  on my 78 argo if one of the plugs in that area comes unpluged it wont shut off with key.ill look closer and take some pics when i get to the farm(where i keep my toys)
                  You never know till you try it
                    just looked,i have 3 wire plug there,2 yellow(1 striped)i assume charging,3rd hard to tell maybe brown????also runs to flywheel area.i think the kill wire to mag.its in an argo(1978)2 wires should be coming from the "block"looking thing that i belive(not sure )is a regulator and /or rectifier,HTH
