can anyone help me? I 16 hp Briggs & stratton engine that will only run on full choke. first, I checked the fuel the pump seems to be working and the carb has gas in the float bowl. next I pulled off on of the heads but the head gasket seemed ok. I still have to pull the other one any help would be appreciated.
Dazed and confused
Try cleaning the carb/ports. You probably have some sediment in there somewhere. A bristle from a wire brush works well for cleaning each hole and then spray some carb cleaner through each one. Be sure not to miss the main one in the bottom of the bowl. That is often the culprit but you have to pull half the motor apart to remove it.
Good luck!
