Help Please
  • Help Please
    I have an argo 750 efi. was running great. when I went to start it yesterday,
    it would not keep running. It would fire, run for a few seconds and quite. I pulled the plugs and it is flooding. dried plugs waited overnight before installing to allow cylenders to dry. Today, same problem. Is there something
    I am missing or can check?
    Want to go 8 wheeling today......
    got to be in your computer or injectors are stuck opean might want to check the oil to make shure you doin't have fuel in it . is your battery charged fully ? sometimes low voltage to it can make it act funny . . robbie
      Help
      __________________
      Thanks Robbi, I will go and look. Battery is good. If it computer, it sounds expensive. I am not sure I know where to look at the injectors but will try.
      Let you know how i make out...
        __________________
        i doupt if you can see the injectors they should be in the cyld head but your computer controlls you fireing of injectors timeing and duration . is the koher tbi or does it use seperat injectors. ? i do not know/ i'm shure ken bost can tell us he know them well . hope you get it figered out . might want to pm ken he is on this ste so send him a pm robbie
          Re: Help
          Thanks Robbie
          I found a plastic connector to the filter that may have been faulty. Dealer says it was on a recall and original owner should have changed out to a
          brass fitting.
          Any way, I changed it out and the filter. Took some time to fill the filter with fuel, but when it filled the motor started. Also changed out the plugs.
          It runns great now. Pretty amazing. Dealer suggested I watch the tank when
          it gets lower on fuel for possible dirt in tank. I will pick up extra filters to carry. Pretty amazing as I believed it was flooding, and it was a fuel line problem.
          the good news is you set me on the right path and its working.
          I guess this is why we belong to the forum.
          thanks
          Happy Argoing to all.
