I'm not sure if I'm in the right forum but i'll ask anyway. What is the safe RPM for a stock 18m kohler engine in an Argo.This is a transplant into an 83 6x6 and not really sure how to set the throttle up. I don't want to blow it up.I have it set now at approx 3500 with no load but also no power when under load. I am bypassing the governor because with it I also have no top end power with it hooked up. Any help would be appreciated. I have a digital laser tach so I can get very close to what ever RPM is recommended.
engine RPM
The minimum rpm on this engine is 2,400; maximum is 3,600, with throttle and choke plates wide open.Originally posted by spits View PostI'm not sure if I'm in the right forum but i'll ask anyway. What is the safe RPM for a stock 18m kohler engine in an Argo.This is a transplant into an 83 6x6 and not really sure how to set the throttle up. I don't want to blow it up.I have it set now at approx 3500 with no load but also no power when under load. I am bypassing the governor because with it I also have no top end power with it hooked up. Any help would be appreciated. I have a digital laser tach so I can get very close to what ever RPM is recommended.
Unless you have bottomless cash in your wallet, I would not recommend bypassing the governor on any air cooled engine. Parts WILL overheat and toast, especially in our application. If you can't reach 3,600 rpm, it's better to fix the system than diable it. A governor is there for a reason, for sure.
Start by making sure your governor shaft is rotating freely, buy a new governor spring, and place it in the 5th hole from the pivot point, and on the throttle control lever it's the 6th hole from the pivot. This is the starting point on Kohler KT17/M18 engines.
Now that you've done that, don't mess with the governor anymore, and move on to your carb.
If you haven't replace your fuel filter this year, go ahead and do that. If you haven't had your carb open for a while, take it off, drop the bowl and make sure it's clean, and the float level is set properly. Put it back on the engine, and then make sure your hi/lo mixtures are set and idle speed is set. Remember when you set the high limit, it's not to the 3,600 rpm level, it's to the max rpm that a slightly rich side of lean will produce.
Now, with your engine warm, is the time to go back to your governor. Run the engine wide open, and move the governor spring on the throttle side to adjust your high rpm up or down to 3,600.
I've done this procedure plenty of times, and not once have I had any problems getting this engine, with all of its systems in proper working order, to do what the book says it should.
Hope this helps,
Planter Bob
nice tach there roger what kind is it ????????? my max II is set to turn 4500 . 4300 under load . the kohler will be turning about the same as u are after busco . sweetttttttttttttttttt robbieOriginally posted by Roger S View PostLast edited by rdr; 08-28-2009, 08:18 PM.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
R.I.P sage rogers 4 11 09 .
It's an Equus.. think I spelled it right. One of the few that work on a vanguard.. firing every revolution. They make a smaller one, and a few different styles and rpm ranges.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
thanks roger . we going to see that bad a$$ argo down this way in oct . robOriginally posted by Roger S View PostIt's an Equus.. think I spelled it right. One of the few that work on a vanguard.. firing every revolution. They make a smaller one, and a few different styles and rpm ranges.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
coollllllllllllllllllllllll can't wait . mike has a thread on posting pic . on the site . robbieOriginally posted by spits View PostThanks for the info guys. Set it up as PlanterBob said and works pretty good. If I can ever figure out how to post some pics of the transplant I'll do so.1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
