will this motor work on my attex? I can get a good deal on it just need to know before I buy
artic cat 340 motor on an attex?
heres a pic of a 340 http://www.snowmobilelinks.com/Quad%20Plug.jpg
how do i install it to be correct
The carb should be in back and exhaust forward, which is backward from stock. I have not Idea if it will work or not but some singles cylinder engines can have the whole top end lifted up and turned around. I have no idea about that on your engine. Or you may have to run exhaust differently.
No, just the top end, the bottom of motor stays the same rotation. The rotation is basically set by spark timing and the direction of the pull rope. Both of which is on the lower end. And not every motors cylinder stud patterns are the same on both sides so you can't always do that.Originally posted by ArgoH2 View PostI would be ok with a different exhaust setup but if it were spun around wouldn't the tranny spin backwards??
motors
As long as the motor is spinning clockwise,,, as u r looking at the pull starter, it will be fineOriginally posted by ArgoH2 View PostI would be ok with a different exhaust setup but if it were spun around wouldn't the tranny spin backwards??
if you don't want that motor, let me know,,,,,
