My Kohler 440 has developed an issue that I need to help figuring out. The problem started back at Phillipsburg with hard starting and seeming to idle only on one cylinder. It bogs coming off of idle and then there is a change in the exhaust note (like a puff) and the other cylinder comes to life. Top end power is good.
I have changed the plugs and plug wires. I've gone through and cleaned both Mikuni carbs making sure everything is clean I even made sure the pilot system was cleaned out with a fine wire. The fuel lines are all new and I checked the fuel pump and that's clean. The carbs are synced as far as I can tell. I changed the crank seals and head gasket recently. I tried spraying starting fluid in the seals with no rpm increase. It was timed and compression checked so unless something happened in the few hours I've run it they should be good.
That's about all I can think of. Let's hear some ideas!
Mike
Mike
!!!!!!! also check all your wires back to the coil and make sure its not shorting out.all it takes is a pinhole to short it out.You can also check the coil and see if its weak.If it was me Id also run an compretion test. ( both sides) to see if they are close to each other.Good luck..
