Anyone have a wiring diagram for the OH160 Teccumseh in a Max II?? Maybe a pdf file?
Wire diagram for Tecumseh?
What about a carb?
Could someone please tell me what carb was used on the above stated set-up? The PO had installed a carb off a motorcycle plus an electric fuel pump, which is a combination a WAY too much gas. I'm looking into replacing the MC carb with an original or better suited carb with a pulse pump. Suggestions welcomed on carb set-ups.
I have one that has a Walboro carb which I believe is original. I will try to check the model tomorrow before I go to work. My machine has a Mikuni fuel pump as well which is connected to the carb with a T that allows a return line back to the fuel tank to prevent overflow. I can't help with wiring since the po of my machine cut out the rectifier so I am still trying to figure it out as well.
Here is a good manual on it.
Chapter 8 page 47 starts the electrical. The schematic isnt labeled with colors though so you may have to just trace wires back.
This was quite helpful to me.
I have been trying to decide if I should replace my Tecumseh. The thing runs great, I just don't know anything about it. It does not smoke. I am thinking I might go through the carb, and maybe even pull the bottom end and have a look. Now I can. Thank you
