rope recoil help
  • rope recoil help
    i have a rope recoil which is in pieces and need help. when i bought my attex the previous owner had priorly taken apart the rope recoil for the 400cc jlo. and now i dk where to even start on it. do i have everything? if not where can i get parts for it? and how does it reassemble (such as a manual of how to reassemble it)?
    missing in action.....
    seems you are missing tiny springs and spacers etc.
      where can i get the things needed to fix it, or am i best off to just call up richards relics and order one of his used ones?
        starter
        Hum,, go ask for a price..... then ask anywhere else,,,, hint hint
        Amphi-relics? a non "bussiness"......
          k, well i think there is a couple of springs in it so i'll take a picture of the little pieces rolling around in the recoil and post it when i get home this evening. i would be more than appreciative if you could help me out with what parts i don't have though..
          Thanks
          Nate
            this is all the pieces rolling around inside my recoil, so tell me what i need "one and only"
              I'm going from memory, but that looks like about everything. There's two sizes of the cups that go over the springs- each spring gets one of each, and the spring/cup assemblies go into the end hole of each clutch dog. The cone-shaped piece is for the cable to wind around in the handle. If I can find a good picture in the manual, I'll scan it.
                thanks don, this helps out alot and gives me a good starting point in which to work from. pics never hurt...
                Thanks
                Nate
                  pull starter
                  Ahhhhhhh! I didn't see those b 4
                    manual..
                    Don,Are you goin to post it? i think u r,, just checking
                      yea, i didn't zoom in enough in the first pictures to show it but thanks for the help guys now i just have to get it back together. i hate buying stuff already disassembled , i like being able to take it apart myself so i know how it goes back together lol
                      Nate
                        Here's the scans from the manual that cover the recoil for the JLO twin. The pics are not very good, but the text covers most of the process.
                        [IMG][/IMG]
                        [IMG][/IMG]
                          thanks again don, this will help out alot. i appreciate your willingness to help me out guys.
                          Thanks
                          Nate
                            well guys im back for some more advice on my recoil. i have three items that i still don't know where they go , otherwise i'm pretty sure i have the rest of it figured out. there's a small screw with a star type head (or its otherwise striped out ), a spacer type looking object...? and a thin plastic threaded nut...? they are pictured below.
                            Thanks
                            Nate
                              The "spacer" is the other piece to hold the cable into the pull handle. The piece goes into the handle with the flare out, the cable comes through it then loops and goes back down. The wedge-shaped piece that you had in an earlier pic goes inside the loop and pulls into the ring that's in the handle. There are two grooves in the wedge that the cable fits into so it fits down into the handle, almost flush.
                              There was a nylon cup on some of the recoils that fit onto the outside of the recoil where the cable came out. The nut probably went onto the fitting as a lock.
                              No ideas on the extra screw.
