I might have a kubota D600 three cyl. to put in my maxII, anyone ever put a diesel in a 6x6???
kubota?
not yet but pm don he has a 2 cyd for one of his mechines . robbieOriginally posted by evil_jim74 View PostI might have a kubota D600 three cyl. to put in my maxII, anyone ever put a diesel in a 6x6???1999 max 2 18 b&s 22 tires custom . new max iv 23 k 26 i/n tires brown . ht cable promark winch . new toy 1972 attex st400 400ccjlo and she will be bad . ( the frog )
   if it don't float with out you getting wet .  don't bring it !
    R.I.P  sage rogers   4 11 09  .
      you can't fix stuped  !!!!! raceone 3 .)
Hi.
I put an 18.hp Kohler diesel in my frontier 6x6. Tourquey.
KD425-2. Got the add on recoil starter for it as well.
No regrets so far.
It is 43lbs heavier than an equivalent 18hp Vanguard gas powered. However the torque is more like a 30+hp vanguard.
I did need to weight balance the argo just a bit.
I also now do not have as much trouble going up hard pack shores. There isn't as much sudden rpm power you see in gas engines, therefore there is less bounce.
I found the extra 43lbs made a distinct improvement to the frontier.
Good luck.Last edited by cobalt; 11-13-2009, 06:26 PM.
Hi.
Yeah has about 30ft-lbs of torque
About 115lbs total after the first oil change and about 30 hours run time.
Kohler Engines: KD425-2: Kohler Diesel Air-Cooled: Product Detail: Engines
Your right that 160lbs is rather heavy . If my diesel was over 120 lbs i would not have installed it in a 6x6.
I have worked on the diesel engines in my kubota RTV UTVs and they are very heavy. Actually far too heavy as they cause the front end of the utv to flip upwards far too easily.
Good luck.
