I have one of the 20 HP now putting out 30 HP Bandolero engines in my Max. Sometimes it does not want to turn over, just dead stopped during cranking. If I hit the key a few more times, it usually will start. Is this because I do not have the original cam in the engine? I am going to try a larger battery, clean cables and connections. Anything else I can do to make sure it will start in cold weather? I did pull it over by hand and it pulls hard on compression stroke.
Thanks, David
Thanks, David
