kohler 440ax
  • kohler 440ax
    i just replaced both coils the points all new crankshaft seals and rebuilt carb and got brand new plugs and wires. both plugs are firing and my motor will still not crank even spraying starter fluid will someone please give me some ideas on trying to crank my hustler
    have you tried switching the plug wires? when you replaced coils you might have hooked them up backward (wrong trigger wire to wrong coil). if that's the case the plugs would be firing at the wrong time.
