Hi all,
Glad to have found this forum as a relatively new owner of a Max IV. I got it primarily to get to and from an off-the-grid cabin up in the Cascade mtns in Washington state. It has the nice snow tracks and all.
I'm having two issues and I think they're both probably straightforward, but thought I'd try to look for more input since I only have one shot per weekend to try to fix any issues.
Issue #1 - after sitting for a week or so, it starts up fine, then bogs down about 5 min into my ride. If I'm careful, I can usually stop and keep it from dying, wait a few seconds, then keep moving forward. I tried varying my speed, but that didn't seem to help much. The best solution seemed to stop and idle or go easy every few 100 feet or yards. After 15 minutes of running, it seems to get better.
Is this just an issue of the engine being cold? Any thoughts?
Issue #2 - at the end of the weekend, after it sat overnight, I added about a half quart of oil. Being an idiot, I may have added to much because I didn't look carefully at the line. It started fine, but then would die after 5 seconds of me throttling it. So I let it idle for 5 minutes and tried again. Same result. Each time it would run hard then the throttle would be unresponsive and die or almost die. From looking at other posts, I'm guessing it's that I overfilled the oil and now need to drain some oil, change my air filter and maybe even change the spark plugs. Does anyone have thoughts about whether I may have other problems going on? I'm running and storing this in below freezing weather, so perhaps there are other precautions that I need to be taking?
Thanks for your ideas and advice.
JD
JD
