I directed the crankcase vent away from the carburetor (into a bottle) and this has fixed the problem of gettng oil into the carb at WOT.
Now my problem is that if it get into rough terrain (ice ruts on the lakes), the engine will backfire, loose power, and generally let me know it isn't happy. I was wondering if my float could be set too high and excess gas could be splashing around causing trouble.
The engine is an 18hp Vanguard.
Any thoughts?
J
Any thoughts?
J
i have a 1998 response with 18hp vanguard i went to use it the other day and fuel pump went out .well i have a 16 vanguard brand new that had a fuel pump on it so i swapped them out now i get the same problem after reading this I'm leaning toward the fuel pump because it didn't happen until i swapped them. the original was square pump the one off 16 is round one. i don't know if this helps but I'm gonna order a rebuild kit or new replacement pump ill let you know my outcome and watch this thread for updates from others
.i orderd the part about 25$.i will post back if this solves my problem hopefully this helps
