I know this has probably been asked a hundred times but on a Briggs and Stratton Vanguard commercial 18 horse how do you measure voltage off the regulator on the engine I checked AC voltage with the regulator unplugged and its about 30volts or more at almost max RPM but when you plug the regulator in do you check the charging voltage from the red wire coming off and to ground on the engine with the multi meter in DC volts
I am sure the regulator is bad because I have heard that running the engine without a battery is hard on it and can wreck it plus no matter what I try I cant get a voltage reading off of the regulator its kind of frustrating
if it had an alternator I would have had it hooked up and charging a long time ago when it comes to small engine charging systems I am lost and running out of ideas please help
thanks AussieMax
