Mike, I've put Fuel injection into 4 different jeeps. The set up I'm running in mine is a fuel cell with baffles in the center of the cell. The baffles look like 2 boxes with one wall missing. [ ] Over lap the front and back walls leaving about a 1/4" gap. As the fuel sloshes back and forth it fills the baffles. I use a frame mounted fuel pump out of a ford F-150 truck, with a screw on filter on the bottom of the fuel cell. You can also use a in tank GM pump in the center of the baffles.Both pumps produce 45psi, and can be bought at any napa. I don't think the foam is going to work off road. It will slow the sloshing down, but in off camber situations you will still end up with all the fuel on one side off the tank. Baffles will trap and hold fuel around the pick up.
______
| _______
| o |
|______ |
_______|
______
| _______
| o |
|______ |
_______|
