kohler 440
  • kohler 440
    would it be worth while to get a electronic ignition conversion from richards to do away with the CDI box on my engine it will only fire on one cylindar
    CDI IS electronic ignition.
    '70's Argo 6x6 - Rebuilt from the ground up. Briggs 18HP Opposed Twin.
    Go where you want, don't get stuck, keep the rubber side down.
      so where can i get a replacement cdi box that is silver with fins like the one i have
        CDI would be a sealed, black box. Silver with fins sounds like a regulator/rectifier. That would not cause loss of spark on one cylinder. Does that motor have a common coil, or 2 seperate coils?
        Attex Super Chief - Sold.
          2 coils mounted on motor
            If you have spark on one cylinder only, (After checking the connections of course) switch the coils and see if you have spark on only the other cylinder now, if so, the coil that won't fire is cause, if not, point/condenser on faulty side. Good luck
              Is this an older 2 stroke, or newer 4 stroke?
                older i guess probably late 70s
                  we've got a kohler 400 sittin at the shop, definitely check the things 6x6 said, points, condensers, wiring condition, plug wires etc.
