Is this a voltage regulator or cdi box, anyone able to tell me how to properly wire this up?
voltage regulator?
hard to tell with the small pic. does it just have 4 small wires running to/from it, or are there plug wires as well? any markings on the unit?A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
So that converts the ac current from the stator to dc and regulats the volts also?Originally posted by KrS14 View PostThat's your regulator/rectifier.
There should be 2 wires coming from the stator. Those run into the rectifier. The one wire comes out for dc volts. I am not sure if its regulated or not.
CDI's don't have fins, and that old 2 stroke will be points/condenser.
The reason Rec/Reg's have cooling fins, is because it has to convert the extra voltage to heat to keep you ~ 14VDC when you rev her up. That's what the "regulation" part is for
'70's Argo 6x6 - Rebuilt from the ground up. Briggs 18HP Opposed Twin.
Go where you want, don't get stuck, keep the rubber side down.
I posted a link in another thread on here, the service manual for the kohler 2 strokes, it may help you out some.'70's Argo 6x6 - Rebuilt from the ground up. Briggs 18HP Opposed Twin.
My question wasnt very specific but you answered mine. I was curious if the recifer also regulates but sounds like it does.Originally posted by KrS14 View PostCDI's don't have fins, and that old 2 stroke will be points/condenser.
From the manual:
On battery equipped models, the leads from the alternator are brought out to a rectifier to convert the AC to DC which must be done for charging the battery. On manual start engines without battery, rectification is not required ; there-
fore, one lead is isolated and the other is brought out to the light switch .
Some applications use separate voltage regulators which control voltage regardless of load--most,
however, have unregulated systems which are controlled only by amount Df load . To avoid an over-
voltage condition on non-regulated systems and resulting rapid burn out of bulbs, always recommend
using full output of the electrical systems . If the vehicle lights seem excessively bright, this usually
indicates an overvoltage condition--on the other hand, dim lights could indicate that the load is too
great. For example, if you have a manual start engine with a 40 watt system, use a 5 watt taillight and
a 35 watt headlamp to total 40 watts . Get as close as possible to capacity but don't exceed it . On the 75
watt systems allow 15 watts to charge the battery on electric start models . On manual start models,
use a resistor of appropriate value to make up for any load not used for lights .
Again, these are for OOOOOLD Argo's, like from the 70's that used the kohler 2 strokes.'70's Argo 6x6 - Rebuilt from the ground up. Briggs 18HP Opposed Twin.
Actually reading further into the manual, you may have a CDI type ignition system on that 440. Please download this manual and match it up with what you have.
