Ok my OH16 exaust bolts are striped are there any tricks to fixing this . Will a hele coil fix this or will drilling and taping be my beast bet ?
oh16 exhaust
If you have access to a heli-coil set of the correct size, by all means use it. This way if you have to pull the bolts again you will not be dealing with a steel to aluminum match, which is usually problematic at best. Never sieze the exhaust bolts liberally during assembly, and it should save frustration next time.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
max2 with 3000lb winch,split shifter, off road lights, and 50 amp alternator
