Hi Folks,...I've got a 70 ish Camel, Very low hours, but the 223 engine is rusted shut....it has the carb on the front......Can a guy roated the piston, and cylinder and head assy so it will run the other way?......If so Can I rotate the top end on a 292 to allow it to fit into the chasis.....?..And would the ignition need to off set or repalced with a different module?....Thanks
JLO 223cc and 292 engine rotation?
Camel Engine compatability......
Howdy, I've got a nice little camel, but the engine is locked up do to rust..It's an R model with the carb in the front and the exhast running to the rear......Is that jsu a basic 223cc JLO with the top end rotated 180....?....And can anyone recomend a a place to get an overhaul kit for A Rockwell/JLO 223cc R overhaul kit?, Thanks Jon
