issue i'm having. with my machine when i turn her over to start it'll only fire once i have let the key back to the (on) position?as it turns over there isnt any spark, until the key is returned to (on) pos. only then will it show spark, ( i took out the plugs to see).front of the engine plug was wet and the other was dry, same front plug didnt show any spark at all , only spark from the other one when said key motion was applied? do i have a bad coil?on the front plug? shouldnt the plugs be firing all the while shes turning over.think i should order a new coil and ignition switch? any advise would help, thx for the help T.
cranky conquest no fire until keys gets turned back(HELP)!!!!!!!!
were you using a spark tester to check it, or grounding the spark plug? if you were using the spark plugs, the first thing i would do is to replace the plugs. also, if you have resistor plugs, make sure the screw on resistor on top of the plug is tight.Last edited by racerone3; 04-16-2010, 11:17 AM.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
If it has spark in "On" but not "Crank" position it sounds like a faulty ignition switch, (Possibly switch replaced with wrong one or improper wiring. (Maybe accessories are turned off during cranking, and it's wired wrong, turning the ignition off during cranking instead? Long shot, but another thought) Other thought would be too low voltage for spark during cranking? I'd pull over by hand in on position and see if both have spark, also unhook the small lead to the solenoid and just make sure it can't touch ground, now have someone hold the key in "start" position (It should not crank with small lead removed from solenoid) and pull-start to see if you still have spark, if you no longer have spark I'd suspect the ignition switch. IF you do still spark, maybe a weak coil that can't produce a spark at the lower voltage? I'm just thinking out loud, I've not had this issue on any sort of engine before, sorry.Attex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
Originally posted by magger View Postissue i'm having. with my machine when i turn her over to start it'll only fire once i have let the key back to the (on) position?as it turns over there isnt any spark, until the key is returned to (on) pos. only then will it show spark, ( i took out the plugs to see).front of the engine plug was wet and the other was dry, same front plug didnt show any spark at all , only spark from the other one when said key motion was applied? do i have a bad coil?on the front plug? shouldnt the plugs be firing all the while shes turning over.think i should order a new coil and ignition switch? any advise would help, thx for the help T.DESTRUCTION is just a couple of vowels down the street from DISTRACTION
THATS EXACTLY WHATS HAPPENING!!!! i so glad you posted! ok now i have removed the brand new battery and recharged it (was at 32%) left on the draw. you say you replaced the ignition, well i looked at mine and appears to have been solderd wire to it. where did you get your new one?
new ignition cures all!!!
hey yall just wanted to post that all the problems i was having with my conquest are OVER!!! turns out a 21$ ignition switch is all the demon needed BIG THANKS TOO ALL THAT HAD INPUT TO A CURE!!! this site is awsome and beast runs so smooth now i took the for sale sign off it lol
