2005 argo avenger fuek problems need help!!!!!!!!
  • 2005 argo avenger fuek problems need help!!!!!!!!
    I am having issues it will run good for about a minute then die like its not gettting fuel. i took the carb apart cleaned everything . then it runs awsome again then dies . could it be the fuel pump isnt sucking enough fuel? anyone else have this problem?
    thanks
    What motor does that have in it? Are you sure you got every port / hole in the carb? Does it run with the choke out?
      I have a 05 avenger. Did the same thing to me. I had a bit of water in the fuel. Put some gasline antifreeze with water remover in it into the tank, and changed the fuel filter. Fixed the problem.
      either way I would change the fuel filter and/or try to run it without the gas cap on, just incase the cap is plugged
      Hope it helps.
        took the fuel pump apart. the spring in the pump mechinism broke and only half the spring was there. so it wasnt pumping enough fuel.!!!
