OK, I am no Small Engine Mech, but I might be well on my way to justifying a new 29hp for my Conquest 2004.
Symptoms:
Smoking a bit when started
Seems to be loosing power when it gets hot
Knocking when under load (Stops knocking when more throttle applied, sometimes) This is what buggs me the most
Almost 700 hrs on engine
Engine seems to be getting hotter than normal , on trips that I've made plenty of times before.
Clutches are new and in good condition.
Belt is good
Trans is fine and not dragging.
I was told to set the valves to .001" clearance, is this correct?
I can do a compression test, but what press should it be?
Could "Timing" be the problem? How is it checked/set?
Yes, I could go to my local Argo Dealer and ask them, but I believe I would be just as well off asking my dog
Any idea would be appreciated
I have the OK from the "Pettycoat Gov't" to go ahead and order the new engine, but would also like to make sure this one is in good condition before I pull it out.
Symptoms:
.Almost 700 hrs on engine
Belt is good
.Any idea would be appreciated
), and I also fixed the heat shield around the exhaust (Knocking noise has mysteriously vanished
27hp)
