hey guys, i just reinstalled the motor on my wild wolf after a starter change ( thanks Don ). when i turn the switch to off the motor does not quit. There are 3 wires coming out of the jlo 2 yellows and one black. when i ground the black wire, the motor will die. Coming out of the voltage reg. i have 2 red wires and 2 yellows......i am pretty sure the yellows fron the motor and reg go together but have no idea about the reds or black. couldn't find a schematic with the seach engine....any help would be appreciated.
jlo kill switch
Hey, Rob;
The reds should both go to battery positive and the black is the ignition kill. If it doesn't shut down when it's on the switch, check your ground wire from the switch to chassis ground.Stuck in the seventies- not in the swamp.
