no idea....it is just set to whatever they did when it was rebuilt.....where should it be?
Help with Kohler 2 stroke Carb
Start with both mixture screws at 1 turn out. The one with the tee bar is the hi speed one, the other is for idle speed. A manual is available at till3
I just tried it and the web page seems to be down. If it doesn't come back up I will scan my hard copy and post it for you. Way too much fuel can be caused by lots of things though, stuck or bad needle valve is the first thing that comes to mind. Many of the rebuild kits are not including them, and the needles have a rubber tip sensitive to cleaning chemicals.
It was just rebuilt from the company I bought the carb from....I will check the neddles though and see if they are good and free. Is it possible to reduce the fuel flow with a smaller fuel line or at least restrict the fuel flow? Would that help? Could it be it needs a bigger return line? Not enough room for the fuel to get out? Also is it possible that if the fuel is too rich it would not be burning it all very well? I know it asks for 20-1 but we are running 32-1 curious if I need to drop to 50-1 or so? Thanks for all the help so far
How do you know the fuel flow is too much? Does the machine start? are the plugs fouled? Does it just smoke allot? Is it drive-able? The high speed needle and low speed needle adjustment will shut off the fuel flow when they are screwed all the way in. it sounds like the machine may smoke allot and you think it is too rich. if the engine smokes allot that is a completely different problem.Acta non verba
Yes it is smoking allot right now....we thought it may be too rich? As for the fuel....it is spitting out the top of the carb and filling the intake with fuel...it is also running very boggy which we thought would indicate to much oil too?The return line is filling very quickly with fuel as well and seems to have trouble keeping up with the overflow.
Inside the carb there is a lever that pushes on the needle valve sealing it into the seat. (shutting off fuel flow) A diaphram actuates the other end of this lever. If the lever is not set right it could cause your problem.
The smoke and boggyness is not from too much oil, that would foul your plug. It is from too rich of a mixture probably. Check your mixture screws.
The built in fuel pump is capable of pumping many times the fuel that the motor can burn, so your return line will carry alot of fuel back to the tank. I routed mine back to the supply line.
We are not running two seperate items, Oil and Gas....it is a premix we are using in the Argo...right now it is set to 32-1 or that is the mixture we are running at least....
So basically what I am hearing here is all this can be fixed by just adjusting the carb? The high and Low screws are set currently to one turn out and the lifter on the needle looks to be right...it is near level across....
