Well, I finally got my JLO 300 running (after new points, condenser, and coil). Ran on the bench really nice. Re-installed to the B/W 7000 tranny in the ST300/D. Hooked up everything except the electric sytem (battery, starter, etc.) so I've been pull starting with a rope (ugh!). Adjusted the calipers to what I think is correct.
Problems: 1) engine wants to bogg down when opening up the throttle. (I've got a new spark plug and am running high test gas). I can get it to idle real nice (for a 2-stroke!), and I can get it to high rpm by being real slow with the throttle. What can cause this 'bogging' down under initial full throttle?
2) Once I get under way, I can't get it to steer. Pulling back on one or the other steering lever causes that side to lock like its supposed to, but the other side doesn't have enough power to turn me. So, I just sit there and I feel the other side just jerking a little trying to turn. (btw, I only have 4 of the 6 tires mounted; fronts and backs; can this make turning harder/impossible?). Any ideas what to look for to correct this non-steer condition ?
Should the driving clutch close up considerably at high rpm and force the belt real high in the clutch? I don't see it closing by more than 1/2" to 3/4" on the shaft. And, I don't see the driven clutch on the tranny opening hardly at all (I thought I had cleaned/lubricated both of them so they could operate freely). Maybe I'm not getting the rpm's high enough because of the bogging ?
This has got me baffled. Adjusting the high speed "screw" on the Tilutson HR carb doesn't really seem to affect the 'bogging' problem. I'm pretty sure its getting enough gas (new in-line gas filter is clear).
You guys with JLO/Attex ST300 experience, I hope you have some suggestions for a newbie trying to get his 'project' running great !
