Put a new batt. in 78 Argo.put multi meter on it ,got to 16.9 volts before i turned it off.thinking this may have caused the batt. to fail in the first place.Any suggestions to control voltage since Techumseh is no more?I assume this is the square shaped thing on tin flywheel cover (regulator/rectifie???r)Thanks in advance!
OH 160 overcharging???
After a lot of research someone at Richards Relics came up with a Kohler part that should work,a kit "full wave conversion"reg/rec.Rated 25 Amp,EFI(if it matters)compatible.Over voltage protected.Kit # 24 755 144-S.regulator/rectifier #25 403 21-S.Will try to install this weekend,been a busy summer!You never know till you try it
