does anyone know the torque spec for the flywheel nut on a tecumseh oh160
oh160 torque spec
25 ft.-lbs at 2,800 RPM found through a google search on My Tractor Forum
ENGINE: OH 160 Tecumseh "No longer available"" 01-01-2000" Stroke :4: Valve in head
Electrical System :20 amp "solid state: alternator
Ignition System :solid state magneto-capacitor discharge design with electronic retard
Cylinders :1 cylinder - cast iron cyl. block
Cooling system :air cooled
H.P./R.P.M. :16/3,600 R.P.M.
Torque / R.P.M. :25.0 ft. lbs. / 2,800 R.P.M.
Bore :3 ½" (88.90mm)
Stroke :2 7/8: (73.02mm)
Displacement :27.66 cu. in. (453.22cc)
Compression Ratio :8.70:1
Spark Plug :Champion L86C (gap 0.030)
Fuel Required :Regular
