Hi Everyone,
I have a Kohler CH25 Horizontal Shaft engine. The shaft is 1 7/16" with a 1/4" keyway. The previous owner welded a 1" step down shaft onto the original shaft. The problem is now the shaft is about 10" long so I would have to mount the engine farther to the left in order to line up the clutches. Not to mention the stress to the engine from having the extra length/weight of the step down. My questions are:
1. Should I leave it like it is and try to make it work?
2. Remove the welded on stepdown shaft and the have the original shaft turned down to an inch?
3. Buy a new crankshaft with a 1 inch shaft (part number 24-014-22-S) for about $185.00 and have it swapped out? The crankshafts have common deminsions so I think it is possible.
Thanks for your help.
Al
Al
All new gaskets all over the place and of course new cylinder head bolts on both sides. I am hoping to get it all back together this week and have its inaugural start/running this weekend. It has been an interesting experience but really simpler than I thought. But I am not surprised I could not find a small engine shop to do the work because it is both time and labor intensive. I'm sure once you did a few, those of you, could rebuild one with your eyes closed but for me it is one page at a time. I also ordered a new CVTech Clutch and belt from RR's. I am starting to see the light at the end of the tunnel but I could not have done it without all the great help here on 6x6 World. Thanks and more to follow...
I ran it for about 10 minutes and it did awesome (pretty proud of myself)! I am going to spend some time tomorrow getting it mounted in the Hustler. I believe I can use the two holes pre-drilled in the mounting plate on the far left side but will have to drill the opposite 2 holes since the ones already on the plate are to far apart. I have read where the fixed plates on the 2 clutches need to be about 5/16th of an inch apart and parallel. I am guessing the fixed plate on the drive clutch needs to be the one that is 5/16th of an inch inside or outside of the driven clutch? Also, are there any tips on mounting the engine onto the mounting plate correctly?
