when you floor the gas on my engine it revs up but then the shaft going through engine where acc. linkage is hooked to, pulls the acc back.You can acc. again but the shaft going int engine that linkage rotates on pulls acc. back.You can't even hold it open because of how hard it pulls back on linkage.It's been like this since I have had this thing.Is this like a governor and is it normal,I hope not cause you can't get any speed out of it this way.If I take linkage off shaft it will acc without being pulled back.Problem is I need to have linkage on that shaft for acc. linkage to work right.This is a 16h.p. tecumsch engine.ANY HELP
tecumsch
yea that is the governor you can unhook it and just reroute the throttle cable i do it all the time to everything that i have. just put a spring on the carb to hold back the throttle and hook the cable to the throttle plateIf you can't fly you might as well float...
There is a bolt on the bottom of the governor lingage that can control the max rpm. If you screw it out it will allow the linkage to go back further. Make sure the cable is pulled pretty tight at idle so to take all the slack off making it pull its maximum travel. I would try that first.
I got the direction of screwing wrong and edited it.
