I have a attex 400 chief w/jlo a bought a new mikuni 34mm carb,it starts and runs great but after about 5 min it boggs and stalls,if i feather the throttle i can keep it running.i dont know if its overheating it dosnt see too hot.
Engine boggs
Does it load up with a bunch of smoke and stumble, or does it make a "hollow" sound, just like it's running out of gas. Make sure your fan belt isn't broken or missing, and that there isn't debris in the cooling fins/fan shroud. Most likely though it's fuel. Make sure you have a good flow, if you take the fuel line off the carb and put it into a clear jar and crank it for a couple seconds, you should get a good flow, not a couple drops. I'd change the fuel filter anyways. My guess is somethings making fuel level drop in the carb, or as you get some heat into it it's just getting a bit too lean, which means richening up the carb, cay you post a video of it running / stalling?Attex 295 Wild Wolf: sigpic My Runner
Attex Super Chief - Sold.
did you have the engine running ok before you put the new carb on, or are you just getting it running for the first time? if you are just getting it up and running, you might have bad crank seals. once they get warm they might be leaking causing it to run out of fuel.... the fuel pump is actuated by crank case pressure.A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
i don't know of any kind of quick fix. get a can of ether, and as the engine starts to bog down, spray some between the engine and clutch, if RPM's pick back up, your clutch side seal is bad... kind of hard to get at the other sideA well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
Just my 2 cents. If a seal is bad, (I think Race nailed this one) do them both. If one went bad the other is on borrowed time. The trail is a bad place for engine issues, and air leaks can burn down pistons.Attex 295 Wild Wolf: sigpic My Runner
absolutely, while your in there do both!!! it's just hard to test the one on the recoil side... i don't like spraying ether near the charging circuit and points
you could try removing the recoil starter and use a propane torch (not lit) to try directing some gas into that area????
Originally posted by racerone3 View Posti don't like spraying ether near the charging circuit and points
Why? Fire Good!
I use carb cleaner, works fine and is less flammable.
