hi guys, i hope someone can help me. i have a 2001 argo bigfoot with the standard b&s 18 hp engine. i just bought it and had about 3 good hours of running. then i put an ounce of stabil in a full tank and went for a ride. during the ride every time i stopped with engine running it wouldn't idle. it ran smooth while running only when idling it would stall. it would only idle with the choke on but had lost a lot of power when running this way as expected. i didn't ride it like this. my friend, a mechanic, looked at the carb andfound debris in the small tube at the top of the carb, pardon my lack of mechanical vernacular. he clear this in seconds and it ran great. idled fine with the choke off. he then took it for a ride and it stalled on him and he thought it was out of fuel. it seemed to be flooding out so more carb problems. it was also jetting so much fuel it would spray out of the top of the carb, this all seen while air cleaner assembly was off engine to be worked on. so any suggestions? and now some questions:
1. where is the best place to buy a carb rebuild kit?
2. can anyone tell me the carb info, manufacturer, part number etc.
3. how do you adjust the mixture and could this be the problem, i see a knob on the side of the carb behind the little black grill/ protective plate but can't seem to turn it.
4. do you guys run a fuel stabilizer all the time not just storing, i keep hearing that ethanol is very detrimental to these carbs. does havoc to my yamaha raptor.
HELP!!!!!!!!!!
thanks in advance guys, i love my argo but don't trust it at the moment to do some serious riding.
trevor
HELP!!!!!!!!!!
trevor
