anyone recognize this engine?
  • anyone recognize this engine?
    The numbers on the ID plate are very worn, any help with ID would be greatly appreciated
    it appears to be an onan 16 or 18 hp motor.....linmar i understand bought these out and are still producing them...the onan engine was popular in the Jon deere lawn tractors, some of the case lawn tractors back in the 80's. I have noticed some propane models on floor buffers...you might try this avenue to approach an id.
      Its a briggs strtton from what i can tell either a 16-20 horse engine would like to have that for my max
        looks like a kohler
          I believe that's a Briggs I/C (industrial commercial) either 14, 16, or 18 HP. I had this engine in my Hustler 980 BIGFOOT at one time....great engine with lots of low end torque. It doesn't rev real fast, but it'll pull all day without breaking a sweat.
          Briggs & Stratton I/C Twin Engine 1980 print Ad - eBay (item 250415467425 end time Jan-18-11 14:49:39 PST)
            yep, that's a Briggs. I had swift's old one in a max, and I Have one now in a hustler
              Thanks guys!
                The guys at Heymow have some flathead lovers.. they adapt 2bbl intakes and carbs off the vanny's, or a pair of tilly's, lots of internal mods.. they are big CID compared to the modern twins at the same hp rating.
                AxletheOppyMech1.jpg picture by Roosterlew - Photobucket
                  Its a kohler 18 to 20 hp i have the same one on my old airens tractor its a kt series
                    I can see how some people might get this confused for a Kohler because it does look very similar, but it's a Briggs I/C flat twin......you can tell by the distinct engine tin and air cleaner housing (and air cleaner nut).
                      i think the biggest give away was the oil fill tube..i noticed the briggs is on the right rear of
                      block and the kohler is on the front left
                        this is the flat twin briggs that was in my wife's old max II for comparison
                          I agree Racer, the air cleaner is the same as the 18 hp Briggs flatheads in both my hustlers. Also the intake and rectifier seen in the second photo are a dead giveaway. I have at times thought of upgrading to larger engines but see no reason to, since they both run fine and deliver all the torque that I need. Enough to break axles when pushing trees and stumps with the plow I had on my 950.
                            It looks to be an 18 hp briggs and is same as i have on my Ranch King tractor.
                              Have any of you ever removed the cowling from around the stock exhaust to install an exhaust upgrade? I am planning to change the exhaust on one of mine and see no reason that the tin that wraps the stock muffler could not be removed or cut similar to how they did in these pics. Any thoughts? Experience?
