Does anyone know were i can get a replacement throttle cable .its for a 400 jlo attex with a mikuni vm34 carb,its 6 1/2 feet in length.
Throttle cable??
I went down to Recreatives here in Buffalo, NY. Amphibious Six-Wheel Drive All-Terrain Vehicles: MaxATVs - Call 1-800-255-2511 I got a new throttle cable and handle from a Max for my Attex Thuderchief 440. I drilled the cap of my Mikuni carburetor with a letter "I" drill bit and then I tapped it with a 5/16" (I believe 24 pitch) so the throttle cable would thread in. I then ground off a little bit of the extra end nub and bolted everything back together. It worked great, and now if a throttle cable ever goes back I can just go there and get a Max one, which is readily available."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
