I just got the ATTEX out this year for some fun in the snow (got about 4" here in the DESERT of So. Cal), and it is having major fuel issues.
I started by removing the fuel tank to clean it (WOW what a job!). I replaced the fuel filter and some of the hoses. I got it started and thought everything was fine until it died after running for a few minutes. I checked for fuel at the carb, and none was present. I figured the pulse pump was bad. Off to my local outdoor power equipment store for a new pump. They had a B&S pump in stock (made by Mikuni) and I bought it and installed it. I got it started and ran it around, and the same problem. This time there was fuel coming out of the overflow tube and into the carb, flooding it out. It has a Mikuni motorcycle type carb on it:
Could the pulse pump be over powering the float needle? I removed the float bowl and checked the floats and the float level. Both seemed good, but I lowered the float level anyway. I installed the carb, and the same thing happened again. I also have another carb that I bought on ebay that was supposed to be for an ATTEX (not sure if for a 4 or 2 stroke). It is a Tillotson diaphragm type:
Is there an adapter made for this carb to fit the JLO engine?
Any help would be greatly appreciated. Thanks, Rich
