I found the perfect replacement throtle cable ,order a max 4 cable with lever for a kawaski engine.its the perfect lenghth you must petap the carb lid and cut off the excess
Attex throttle cable
I've been doing this for a while on machines with Mikuni carbs. You can use whatever length you need, Max IV, Max II, Buffalo Truck, along with the Max throttle handle. Then drill the Mikuni carb cap with a "letter I" drill bit. Next you tap it with a 5/16" 20 or 24 pitch I believe, tap. You also might need to cut a little bit of the metal end down so it fits in the round slide of the carb. Then just assemble it and you're good to go."Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
Originally posted by rocketman17joe View Postnow i do have a question,i bought a maxII cable and it was to short I returned it and gat a max4 and it fit.How did you get the MaxII to fit?? Oh i have a 400 chief with a jlo"Looks like you have a problem with your 4 wheeler........you're missin' two wheels there"
