carb cleaning 101
  • carb cleaning 101
    ok i found a secret weapon to sludged up carbs
    before this season of frozen everything i took a few filthy carbs to the test
    i bought a 570 exciter MiC carbs were junk 10 years of varnish and rust
    a stuck choke plunger
    well i did learn this from trying it and the movie grand torino
    if you have a stuck choke plunger MIC KEIHIN ETC it is made from brass , carb is aluminum.. take some plain old white vinager pour a little down the hole with teh stuck plunger and wait about 24 hours then it should come right out with no argument vinager is an acid that eats corrosion incl;yding rust acetic acid=vinager
    so that choke issue was fixxed
    next carbs are full of scumm
    i took a small tub filled it with a mixture of
    60 percent water , 39 percent vinager
    added about 1 ounce of purple powerlike degreaser {{it was cheap}
    i also added some pool chemical otherwise known as salt , rock salt or table salt would work
    after 3 days of soaking all he scum came off anbd i cleaned her off with water first and then used carb cleaner
    like brand new
    i also did not feel like buying new needles and seats so i lapped the needle valves together with rubbing compound
    it worked for me
    your results may vary slightly
    AND REMEMBER TO COMPLETELY PULL THE PLUNGER OUT AND CLEAN ALL CORROSION AS IT WILL DRY AND GET RESTUCK somewhere in my domain thier is a 230 quad toilets carb that i forgot to clean all the crap out and it went back to being stuck
