hello! i have a 197? argo that floods out all of the time. I had the carb rebuilt on it and it didnt seem to help.
i also set the points and replaced the glass ball valve in the carb with a needle valve. the carb is a tilltsion HR42a and its on a 399cc Kohler engine. Any suggestions? Thanks!
By flooding out i mean it starts if you give it full throttle and then it starts shooting gas out of the tailpipe and dies. It happens no matter how warm or cool the engine is. After it dies we pull the plugs out and there really wet and we also pull the drain pulg on the bottom of the crankcase which we get alot of gas out of. weve also tried playing with the adjustments but it is still getting waaaay to much fueol through it. Any help would be great thanks!
i also set the points and replaced the glass ball valve in the carb with a needle valve. the carb is a tilltsion HR42a and its on a 399cc Kohler engine. Any suggestions? Thanks!By flooding out i mean it starts if you give it full throttle and then it starts shooting gas out of the tailpipe and dies. It happens no matter how warm or cool the engine is. After it dies we pull the plugs out and there really wet and we also pull the drain pulg on the bottom of the crankcase which we get alot of gas out of. weve also tried playing with the adjustments but it is still getting waaaay to much fueol through it. Any help would be great thanks!
