I have an older Max II that originally had a 2 stroke engine (not sure what brand, the engine was missing when I bought the Max). I have put in a Kohler 16hp 4 stroke that was originally in a Hustler 950. The voltage regulator on the Kohler engine is bad, and I want to use the regulator on the Max to replace it. The Kohler regulator had two yellow wires from the engine, one wire to the + on the battery, and was grounded to the engine through bolts. The Max regulator has the two yellow wires to go to the engine, a red wire to go to the battery, bolted to the frame, but also has a white wire that I do not know what to hook to. Is this white wire a ground, or would it just not be used on a 4 stroke engine (maybe it was a kill wire for the 2 stroke?).
Any help would be appreciated. I don't want to fry the regulator by hooking it up wrong.
Thanks
Thanks
