i was lucky here at my place, no water at all and had power . some outlying areas are still without power and some local roads are still closed. when you get timex squared away give me a hollar and we'll plan a ride down here.
needing motor replacement.
Originally posted by FREQ42 View PostIt's alive, the muffler came in yesterday and i installed it, it sounds real good. I just need to finish the throttle hookup and I'm still waiting for the electric choke conversion to arrive then I just need to re-wire my key switch to work with the new motor.
Talset how did you fare out over by you? I still have flooding and lots of mud over by me with a lot of roads closed till January?
Originally posted by Dan67 View PostWhere did you get your electric choke from? Where did you order your muffler from? I'm still looking for an affordable muffler.
Filter Side Exit for $129.95 .They wear the cheapest on the net. I got the choke from ebay, I'm going to use a door lock solenoid to move the choke lever.
Originally posted by amphibious drew View PostGet that choke done so you can drive down all those closed roads.
Originally posted by TalSet View Posti was lucky here at my place, no water at all and had power . some outlying areas are still without power and some local roads are still closed. when you get timex squared away give me a hollar and we'll plan a ride down here.
NOW my question is, will i get more cable travel for the throttle using RI's cable and handle or stick with my aftermarket bike handle?
the cable travel i have now is about 1/4" max but I don't know how much travel RI's has?
Originally posted by FREQ42 View PostI got my muffler from Briggs Stratton Muffler Part No. 808896
I already go up/down the closed roads with my truck to deliver gas/diesel to people that still have no power nor any way to get out. One of the advantage's to a big 4x4 truck.
will do, I'm pushing for this weekend to get it finished to the point ware i can drive it around and test it out.
I went with the Filter Side Exit muffler to able to exit out the top of the body,
I fabricated the pipe to be removable for wen i need to pop the top for maintenance.
I'm going to modify my throttle lever to move farther but will call RI for a heated cable and a lever for when mine brakes.
I finished modifying my throttle to move further then took the Timex out for a Little ride around the property at work.
Well it worked good till the bolt came loose and i lost throttle but after i fixed it,
I cant stop smiling even now
It was well worth the change, i climbed hills with no problem's and the motor is supper quiet, I all most hit two deer while romping threw the field.
I called RI today and ordered the heated cable and improved lever for the CMATVA Rodeo coming up.
Alls i have left to do is remove the old muffler and bracket's and cover up the hole and I'm good to go.
TalSet I think if your up to it I would be willing to go out and play for a while and test this out further.
Congrats Bob!!!
Reading your post almost makes me want to go out and finish my swap right now. btw. You were absolutly wight about just bolting it in. Thanks again for the insight you gave me. It encouraged me to have my engine half way out before ups even showed up today, and if it weren't for having to go see another member as well as talking to a few other members on the phone (i always enjoy talking to everyone) it would have been completely hooked up already.l like to buy stuff and no I don't do payments!
well as luck would have it, my fuel pump went on vacation on me on Thursday. left me about a mile from home. lucky for me i was near a highway, so i had my son come to me with a windex spray bottle of gas so he could ride in the back seat and just keep misting gas into my carb. to get back home. as soon as my new pump gets here, i'll give you a hollar and we'll go out for a ride.
Originally posted by TalSet View Postwell as luck would have it, my fuel pump went on vacation on me on Thursday. left me about a mile from home. lucky for me i was near a highway, so i had my son come to me with a windex spray bottle of gas so he could ride in the back seat and just keep misting gas into my carb. to get back home. as soon as my new pump gets here, i'll give you a hollar and we'll go out for a ride.l like to buy stuff and no I don't do payments!
