ok the engine is a kioritz kec 340/5a with a walbro carb(cant find the model) . has the pump at the fuel tank and two fuel lines going in. i was told that this model has the built in fuel pump and looks to be a 70ish model....ran fine till the other day while driving full throttle then shut off , had to pinch the fuel line and keep cranking cuz gas was pouring from the carb but no leak . looks like the flow was too much. got it started then it happened again this time it wont start....after several tries got it to fire and throttle then revved it high and it died again. thinkink needle seat valve but i have a newer mikuni carb here i can put in it in place so what fuel line do i use of the two and do i just plug the other or what i need her running tip top before i can float test her
carb questions-need help
The Mikuni slide carb will need a fuel pump near the carb If the pump has and extra outlet just cap it. Mikuni round pumps have arrows cast in them for direction. The center bottom connection goes to the crank case. make sure your Mikuni carb is for a pump not gravity or you will have to change the float needle.Acta non verba
First you need to absolutly know what kind of mikuni carb it is.
Procycle - Mikuni Carburetor Size Chart
It can be a bit tedous to figure out what it is. I used this chart to figure out i had a VM_34 (which is a 40mm carb) and google search jetting for a single carb VM-34 440 twin with excelent results.
good luck and pop up what kind of carb it measures up to be, ill help looking for you!Alaska floating atvs group on face book. Fixing help and trail rides!!!!!
ATV = Alaska Terain Vehicle
kioritz 340 with a walbro carb wont start
cleaned the carb maybe the 2 fuel lines are reversed on the carb anyone know which goes to which port?
also its a max2 can anyone tell me hot the steering bars come out ? i wqant to bend them slightly so that they sit more on the drivers seat for when i have passengersLast edited by Mike; 07-30-2011, 11:16 PM. Reason: merged two threads. No need for two on the same topic ;)
