Originally posted by mustangwagz
View Post
I took a washer and bored it out to my shaft size then chamfered one side to fit the radius of the shaft ware the shaft go's into the motor to keep the gap from being to big. this can be made using a drill to drill out the hole to your shaft size then using a grinder or file make the chamfer on one side to match the radius of the shaft. or have your machinist friend make you one. you just need enough clearance to keep the clutch from hitting your motor.
