Engine swap - to cut or not
  • Engine swap - to cut or not
    Hi all
    Got an engine to replace the dead one in my 82 argo 6x6. Pulled the old one out and I can't get the new one to go as it hits the top deck infront of my hood. Would need to split the top and bottom apart to do the install. Then cut a notch for the engine top to stick out. Not a big one, but still would be cutting the top. Now I know why the new ones have a high front and shorter hood.
    My question is would you cut it and put in the engine or go shopping for a different one.
    thanks
    PS: the engine is a 45hp 4 stroke single 500 cc liquid cooled with clutch and all needed to make it run.
    Get out the saw, because I'd be making a few slices to that body to get that power plant installed.
      Can you heat the body and remould it. Hopefully without making it ....ugly.
        With enhancements like that in mind, I'd send the old girl to the plastic surgeon.
