I'ts a really tight fit!! Makes the t-20 look kinda small...
B&S Big Block in a Hustler
Awesome! Now you have me thinking about a 23HP Vanguard in my Hustler! I know that Broncrshr fit a 20HP Honda in his. Maybe this will be my next project.
Man......that thing is sweet. You had me thinking today about how much HP I would gain by making headers and putting a K&N on my Honda.......
That thing is going to be a beast........
Are you going to leave the gear ratios alone or maybe put a higher ration in for more speed?Hammers should have warning labels.
Looks sweet! It does look like a snug fit. Do you have an air cleaner figured out. Guess it has plenty of charging system too. Oh besides a ton of stump pulling torque..
Enough power to self clean those mud tires.
Hey guys, thanks for the comments. The hose from the t-20 is just a breather hose attached to a barb fitting tapped into the drain plug with a filter on the other end. After I rebuilt the trans, I noticed that when it got hot the fluid would expand and leak out of the plunger seals and the main seals. I do not know if the factory put breather plugs in these things or not, but I have not had a single leak after installing the hose.
Hey Bon, that Honda would run great with a twin pipe into one exhaust like whipper has on the springer, and a better flowing air filter. I bet it would be good for a couple of ponies. How many teeth are on your main drive sprockets? I am planning to try 28-teeth on the main drive sprockets; I would like to keep the rpm's to 5K max, and the engine build (it is currently stock) will not be too radical. It's already a 54ci engine, so I am just adding stronger rods and slightly higher comp pistons, mild torque cam. I will clean the heads up a bit (although I am told these heads flow well right out of the box), bump up the timing slightly and toss the governor. I am shooting for 45-50 hp and around 60ft-lbs torque. I think it will be scary fast, too fast for a non-suspension machine even with the softer rawhide III 's I plan to use. Whipper, I might need that springer kit after all!
Hey Roger, don't you know the Briggs guys over at Ec Distributing in Dickson, Tn? They sell a bolt on adapter and Air Filter Kit to fit this engine, just wondering if you had used one?
Hey jp, I've got a couple of Kohler Command 44ci blocks that need to be built. Might be a good fit for the 980!
Sounds like you're way ahead of me.. I was going to suggest E.C. or Al Hodge. Didn't know how much stuff E.C. had for the big blocks since the mower guys used to be limited to 20 hp blocks. I've seen the K&N type filter.. figured it wouldn't work on the big block.. Who did you get all your parts from?To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
30 minutes, hehe. You shouldn't have to go farther than a state or two for everything. Next time you're there see if George's dyno can accomodate horizontal shaft engines.
Have been reading about off road areas in N.E. TN, looks like a place to have a ride. Some small private parks, the Cumberland something area, 49,000 acres open to vehicles.To Invent, you need a good imagination and a pile of junk. (Thomas Edison)
There are some great places to ride in Middle and E. Tn; Coal Creek OHV (Oliver Springs) is awsome. 165 miles of logging trails and single track...from easy to "what the heck did I get my self into" trails, with great maps for sale at the parking area. We should consider a ride out there?
The install is coming along nicely. Hopefully I can get the clutches lined up tonight, and the motor bolted in. Tomorrow with a little luck I can weld up the header and hook everything up. I still need to find a longer belt, so off to the gasket house Monday. I plan to break in the engine and then pull it and take it to the dyno shop to see what kind of power it makes., and I will post a build up if anyone is interested in building one of these beasts.
I wonder how long it will take to melt the Duster Drive Clutch...
Should be interesting
I was surprised you chose not to change the jetting. Is that carb user friendly, or like some of the Inteks that are hard to adjust or modify? We'll need a sound clip.
Yea, it is a really basic carb, but big! Each venturi is 22mm. The jetting looks fairly agressive, so I thought I might run the engine to see if it is getting enough fuel before I started switching out jets.
Hopefully I can have this thing ready for the Marengo Ride!
Is it stock?
