Finally got around to pulling my JLO 440 twin carb out and putting in a GX390 clone. Problem I'm having is with the pulse fuel pump running the carb insulator is pouring gas out the carb overflow hole. Anyone else ran into this problem? Looking for a way to fix this.
GX390 clone engine fuel pump issue.
I read that somewhere else also and was going to try it tonight. My other concern is the original fuel line that was on the original tank that i removed was only around 1/8" and all the new stuff is 1/4", is this going to also create a problem because there will obviously a volume increase now. Was also going to pull the bowl and make sure the needle valve is seating properly. Post an update later on.sigpic
